Hi jacobo,
1- I can't change the camera of a certain pass. Every pass renders using the default camera. How do I go about doing that?
If you open the options for that pass, in the Format tab you have a drop-down menu (labelled Output Camera) that allows you to choose the camera.
2- Is there a way to do automic mapping a la Maya in XSI?
Sorry, don't know Maya enough to help you there.
And also, is there a way to create a UV projection based on the surfaces selected instead of on an object basis?
Not sure if it's what you're looking for, but if you select several polygons, create a cluster, then do Property > Texture Projection > ..., it should work.
3- is there a good skeletal setup tutorial that walks you through each basic step?
You can check on these links:
http://hem.passagen.se/boda/
http://www.joncrow.com/
Other valuable sources of tutorials:
www.xsifiles.com
www.edharriss.com
http://www.softimage.com/Education/XSI/Sel...als/default.htm
Hope this helps
Salutations - Cheers
Bernard Lebel
