Hi there, i’ve got some holes in my knowledge about maya and just wondered if anyone can help? if so please could you answer the following questions for me? i appreciate the answers may be complex but a simple explanation would be appreciated.
what kind of spec computer is reasonable to run maya on
in professional productions like shrek, how to train a dragon etc… do they texture models in maya or do they use a second party app?
what sort of resolution should you work at for textures?
would they tend to use procedural materials made in maya or bitmap files?
what format of bitmap image file is best?
when would you use procedural textures instead of bitmap textures?
how do you optimize a texture to cut down on render time in a complicated scene? is this what baking materials is?
are complicated scenes done in different renders and put together in compositing software? if so do they export camera settings to each scene that needs to be composited on top of one another?
if i was to model a complicated scene like a forest, would you do it all in maya or use a third party app? if you use a third party app would you export and texture in maya or in the third party app?
where is the best place to get training on maya?
in a model like a tree where you have lots of little bumps and indents would you use a displacement map or bump map or would you physically model the little bumps and indents or would you just rely on a texture that looked like that?
if you were modeling a mountain how would you get the random variation you see in rock faces?
if you had a character would you use projections? wouldn’t it cause problems as the body parts deformed?
when would you use projections rather than normal textures?
if you were had a character and wanted to texture it, would you detach each seperate body part and then create a uv map for it and texture it individually? and then reattach it? if so doesn’t the texture change to the part your joining it to?
In movies do they mostly model with nurbs?
when would you use an ambient light or a directional light or a spot light or point? what’s the difference?
for realistic outdoor lighting is it best to use the daylight system in mental ray?
even if you can only answer some of them it would be appreciated! Thanks!
something with 16+ gigs of memory a quado fx 1xxx 3xxx or 5xxx card, as fast individual core as possible but as many cores as you can possibly afford, a ssd drive for main os, a ssd for work scratch a 6 tera of raid 5 or drives. + a few additional computers with no gfx card for render farming.
Yes, Tough you cant replicate this even if you wanted to, Simply because youd need skills of 2 differently trained persons.
3-5) not quantifiable, best is not defined. It depends on what your use is, how close the object is going to be to the camera, what aspect your texturing how your laid out your uv, how many shards you have and how you filter the data, and how big you render.
Always when humanly possible.
You dont optimize textures in this manner you use textures of suitable size to bake down things theta re more expensive than texture lookups.
EVERYTHING is eventually put together in a comp app. Its not a question of doing things that you couldn’t otherwise do, but rather a convenience of working effectively.
Depends, mostly you can not think thsi way. Your not actually operating maya, your operating a computer so you mix and match softare as you see them best fit. You allways end up using many things, IDE’s for programming, shells for automating, asset management software for assets, comp apps for comp stuff, compression app, texturing apps, data migration apps, sound applications, math applications, spreadsheets are good for some stuff etc… lots of stuff.
You dont want training. Operating something like maya requires education. Training can only get you so far, and this is a field of adapting info - which is up educations alley. Go to a uni.
all of above + some
with a shader, brush and some scripts. But consider doing a matte painting.
If i need a projection and it makes sense. No it would not cause problems, thats what texture refrences and per vertex values are for
When i need to convert a 2d into a 3d texture, when in hurry, when i have lots of independent stuff and when it makes physically sense from textures nature.
no makes no sense. If i would detach it i wouldn’t bother to re atach it why would I? Theese are not things that are related in anyway.
probably not anymore, but they have benefits for a lot of stuff. Especially when rendering with prman.
Ambient, never unless im making my own shader loop with a shading network in which case i just use ambient as a payload delivery method. Directional = The Sun, Spot and point the rest
If you know how to use it, and dont have any other specialized needs. Dont see much need to use it for myself, its ok if your doing architectural vis.
Actually Tony there are no definitive answers to a lot of your questions as in most cases “it depends”.
So:
The best computer you can afford that is qualified to run Maya. Go to Autodesk’s website to find a list of tested and qualified systems. You certainly do NOT need 16Gb of RAM to run Maya and will likely only need that much for extremely heavy scenes or simulations. Maya will run fine with as little as 2Gb of RAM, though I wouldn’t recommend it. You need more memory as your scenes get heavier and you need to load more file textures.
Every studio has its own pipeline, but in most cases at those big studios they use third party 3D paint programs extensively. Mari is the next big thing in this field.
3-5) It depends. Resolution is determined by how the pixels from your image file will correspond to the number of pixels they will occupy in your renders, with the optimal being a 1:1 ratio. In practice, you usually have to make an educated guess and just make sure they are big enough so they don’t pixellate in your renders. File format doesn’t really matter as long as it’s supported by all the apps you use, though you’re normally better off avoiding JPG and using something that is relatively uncompressed like TIF or TGA.
It depends. Procedural textures have their pros and cons. Some pros include resolution independence, less need for good UVs (in the case of 3D textures). Cons include difficulty in art directing them, noisy in renders. Every situation is different. In many case even when procedurals are used it’s best to bake them out to file textures for final renders.
Keep your file textures as small as you can, reuse them in scenes as much as you can. The objective is to use the smallest amount of memory/RAM you can.
Compositing is part of any decent 3D project, but with render layers and passes in Maya it’s often possible output all the elements from one scene. It depends. More complex pipelines at larger places may work differently.
You can certainly model most things in Maya if you want to. There are other programs out there, like Z-Brush, which may make it easier to do certain types of modeling. Maya can do most things but there are other apps which specialize in this or that. There’s often multiple ways to get to the same result in the CG world.
It depends what you want to do and your experience level. If you are a complete newbie, maybe a community college to get your feet wet. If can get a copy of the software, do so and start doing tutorials (tons on places like YouTube). Expensive college programs will not make you job ready, despite their claims, and the only way to really learn 3D animation is by yourself and with many, many hours of practice. Get an internship or join an online volunteer project to get some production experience.
It depends. With a “Hero” tree that will be seen up close it’s likely to be a combination of model and texture. Objects farther away will be done mostly with textures because it’s cheaper/faster for the computer to render.
Lots of ways to approach a problem like that, such as using a procedural texture as a displacement map (like a fractal). There are also other apps (such as Bryce) which specialize in natural environment type stuff.
It depends. If you really needed to do this you would need to make the projections “stick”, such as with a texture reference object.
You normally only use projections when direct mapping doesn’t work for some reason or there is some advantage to projecting.
Not normally. You don’t need to separate geometry to have separate UV maps. Complex topic though.
Again, it depends. Some things are just more easily modeled with NURBS so they are still around. Everything ends up as polys in the renderer though.
Each light type has its own uses. Get a book like Jeremy Birn’s “Digital Lighting and Rendering” to learn about them.
I haven’t used it but again it likely “depends”. Sometimes those potted systems in Maya are all you need, other times you need to use a more adaptable approach.
No but you dont want to run maya on 2Gb either*. memory is cheap, and in practice 16 Gb is much enough so it never comes to play unless youd doing something insane (8GB comes up quite often tough, maybe 12 is the point where it dont matter so much). Its just not worth it to hit the memory barrier for the amount of money memory costs no matter how light your budget is.
The thing is if your working alone you need more stuff than you do in a studio because your doing everything yourself. So in a studio environment 2Gb can be well enough for some of the users. Also studios know what they are up against you do not, better be prepared.
Well not quite there are analythic renderers out there that use the acttual nurbs data (most of them are hidden line renderers tough or pure raytracers, but theya re usefull for a number of things out there). Also im not sure rasterized micorpolygons count either as true polygons since the renderers that rasterize this way would micorpolygonize even polygons its mnore of a algithim thing**. So this is a kind of white lie they tell people.
I havent used a computer with less than 4Gb since 1997 for example.
** likewise you dont usually call bump maps, normal maps even tough thats jsut what they are. Or maybe a better assimily is taht you dont call pixels polygons even if they really are polygons. In any case its like simplifying math by sayig its all addition. Or like saying the tide is coused by the moon.
