In the movie called in_v15_interactive_renderegion.wmv in the "Innovate" section on the experience CD he uses a shader called "space". Does anyone know where this shader is located?
here is a screenshot of the movie:
Thanks
Thanks
I think that it's just an environment shader that's been renamed. (Probably the Legacy_Night.Preset) Which can be found in: C:SoftimageXSIDataDSPresetsShadersEnvironmentsoft3d
I dont think so, look at the parameters in it, it's very different....
Also, that shader you mentioned has a texture plugged into it, the shader in the movie doesnt...
You are right. Now that I look at it closer it seems to be more similar to the Legacy_Atmosphere.Preset. (Close
Hello,
I used the legacy atmosphere shader for the effect. It has a slight trick to it which is you need to attach it in the render tree. basically...
get sphere
(render tree) --> nodes-->environment-->more go into the soft3d folder and get the legacy_atmosphere.
attach the node directly to the surface input of the sphere without an illlumination node. that should do it. to get the space effect change the view altitude and find a cool map of the world - i think i found that one at nasa.gov. also try scaling the sphere way up.
hope that helps...
mark
