I'm trying to render out a simple scene in Mental Ray (Maya 2008 x64), and I'm getting strange artifacts in my render:
http://i284.photobucket.com/albums/ll35/jh...lockyRender.jpg
This is happening even in a very simple scene (the above is just a single plane with a textured Lambert material applied to it) rendered at Mental Ray's default (low-end) settings. I've tried illumination via either "Enable Default Light", HDRI, or a directional light, but none of them make a difference.
This only happens if I use a material with a file texture. If I apply a basic material (just a colored Lambert, Blinn, etc) or if I use one of the stock procedural textures (checker, mountain, etc), everything renders fine. Also, things render OK if I use the software renderer as opposed to Mental Ray.
I've never used a file texture with Mental Ray before. Is there some part of the process that I'm missing? I've searched here, Google, The Area, gone through the manual, but can't find anything that would explain my problem.
Thanks for any help.
PS I should add that I've tried various file formats for the texture file (jpg, uncompressed tif, targa, even used imf_copy to make a .map version). I've also tried rebooting
