QUOTE(eancarr @ 06/18/07, 05:17 PM) [snapback]268275[/snapback]
Just discovered this node lurking in the shadows. After a little experimenting, got it working pretty well. Plugged in a Star File, works great, no flickering after pan/tilt. Stars are all the same size which I can fix easily enough multiplying by some 3D noise, maybe. Anyone out there have experience using this and want to share some tips? Cheers, -Ean
I've use it only twice and it worked like a charm. I've loaded the txt with the star coordinates and then to play with the size, flickering and colors I've used some noises. There isn't much secret about it, nice node indeed.
If anyone needs the coordinate file for the stars let me know, I can post it here.
Cheers,
diogo
