Startup Settings
Hi
If i safe a shake file there are a lot of information about the shake ui like "globals.fileBrowserWidth", "790". Is it possible to change this value by default if shake starts up? So that i do not have to change everytime i startup shake.
cheers joe
did you try "save interface settings.." from the menu?
it should create a defaultui.h file in the settings folder that you can modify as needed.
++ chris
ps: just found that theres a "globals.fileBrowserHeight" entry as well.. very cool.
thanks for asking
thanks alot!
it works fine. its much easier if you not alwas have to resize filebrowser...
thx
cheers joe
