Sticking Nodes Between Noodles
So, I'm just getting into Shake after years of AE.
Anyhow, I have been going through the tutorials, and it says that you can drag a Node over a Noodle and effictively stick it in the Noodle. For instance I have a Layer Node connected to a Multi Layer Node. I want to stick a Color Correction Node inbetween them. The manual says I can drag the Color Correction Node over the Noodle connecting the two Nodes to insert it between them, right?? But it doesn't work. A coworker of mine, who has used Shake for a few months, couldn't figure out why it wasn't working either, as it seems to work fine on her workstation.
Help?
Thanks
Luke Sullivan
This looks like something that got broken in the 4.1 release. I just double checked 4.0 and this works just fine. There may have been a flag that is turned on or off in the nreal.h file, I will look into this.
Billy
shake-support@shakesupport.com
Haven't tried 4.1 yet, but I read something regarding a change in the "insert node" behaviour. If I remember correctly, it should now work when pressing N while dragging the node over a noodle.
Give it a try and see if that helps.
The "n" option had no affect in 4.0 but does seem to cure the problem in 4.1
Yup, that fixed it, thanks guys.
Luke
