Stitch Curve Point
I would like an option like Edit NURBS --> Stitch --> Stich Surface Points that could work on curves or even polygons.
This would help me when I'm modeling with curves to keep the ends stitched together.
Moogy
you can stitch curves to nurbs surfaces! depends a bit on what you need tough. Also its possible to do thsi roundbout to polygons by same token.
heres a quick and very dirty example:
file -f -new;
nurbsPlane -p 0 0 0 -ax 0 1 0 -w 2.8 -lr 1 -d 3 -u 1 -v 1 -ch 1;
curve -d 3 -p -1.4 0 1.4 -p -2.256132 0 1.4 -p -3.112265 0 1.4
-p -3.968397 0 1.4 -k 0 -k 0 -k 0 -k 1 -k 1 -k 1 ;
createNode nurbsCurve;
projectTangent -ch true -rpo true -c false -rt false -td 2 -ts 1 -ro 0
"curve1" "nurbsPlane1" ;// this is extra im just lazy
connectAttr -f curveShape1Original.worldSpace[0] curveShape2.create;
disconnectAttr |nurbsPlane1|nurbsPlaneShape1.worldSpace[0] projectTangent1.inputSurfaceToProjectTo;
connectAttr -f curveShape2.create projectTangent1.inputCurveToProject;
connectAttr -f nurbsPlaneShape1.controlPoints[0] curveShape2.controlPoints[0];
projectTangent -ch true -rpo true -c false -rt false -td 2 -ts 1 -ro 0 "curve2" "nurbsPlane1" ;
You can also use follicles to stich o either poly or nurbs surfaces (go to duncans corner on autodesk arena). Also then theres rivet method wich does the same but slower.
making a node for this alone wount be impossible tough!
PS: this lead me to find a interesting refresh bug in 2008 that craps nurbs surfaces whan moving a point beyond the bb, basically breaking maya 2008 ability to do any meaningful nurbs edits. Now all i need to find if somebodys doing prank on me
