I have been doing a comp where an image replaces another on a hand held device.
I have tracked the corners into which the image is being placed, and then copied the track data into the cornerpin node coordinates.
The image looks ok when i use the playback buttons, but when i render the fileout node the replacement image appears to have moved a significant amount to the right, leaving a gaping black hole in the comp.
Any ideas what could be causing this shift? and how i can overcome it when i cannot see it in my Shake viewer screen?
thanks
Adam
