Strategy to optimize heavy geometry for preview!
Hey everyone!
What is the best way to optimized heavy geometry to make it look ok in preview? Im working with specific cad models and I need a tool that goes through every peace and if its not visibly in render I want to hide or take it away.
I've got some ideas and I think I'll have to write a custom tool that does the job! What do you people think? Is it possible to pre-render a scene to see what's visible and whats not? and then use that information to affect the "visibility" attribute of the peaces??
Suggestions are welcome!
/Joda
Output a crude polymodel from the cad prog (most of them would do much better tesselation see my rant in the modelling section or go here for just the pictures). Then use theese at proxies and use the hires ones only in final renderings!
Okey!
My problem is that the iGES models are not optmized and I just get the files from our clients "Construction Department" and they dont have time to optimize it...
I need to be able to load it into maya, use a command and "booom" and every part that doesnt show up in the final rendering isnt there.
You see what I meen? Skip the CAD section, I need a tool for every kind of geometry and large amount of data.
Again, is it possible to render a car or similar in a specific angle and then use that information to see whats visible or not, and then it to affects the "visibility" attribute?????
Thanks for the reply!!!
  • Joda
Well i see... IGES isnt perfect, in fact it so inperfect that some data is bound to wanish. However select everything and fiddle with the atribute spreadsheet... check that all the objects you need are set as renderable, make the two sides to confirm its not just a wrong way being normal etc.
Its perfectly normal that any average cad image contains literaly millions of surfaces... i remeber my 3d CAD test scene that contained some 2,000,000 trimmed surfaces. This made maya feel like crap even tough the cad prog could chew the same data in a mechine that was waaay much slower!
hey!
Okey, thanks for the reply!
But problem has not been solved, I still wonder what is the best strategy to determine if an object will appear in a final render or not...
Think I'll post a new subject to the list!
Thanks for all of the replies!
Mike
