Stuck On 'impulse' Attributes
Hey, I'm working on some crowd stuff at the moment, unfortunatly I have run into an error and have been looking at this code for far too long as my head appears to have gone to mush...
rigidSolver -create -current -solverMethod 0 -collisionTolerance .1 -name crowdSimSolver;
setAttr crowdSimSolver.allowDisconnection 1;
setAttr crowdSimSolver.displayVelocity 1;
spaceLocator;
$agentAmount = 10;
// Make Agents
for ($i = 0; $i < $agentAmount; $i++) {
    string $plusMinusNode = `createNode plusMinusAverage -n ("PMAnode\_" + $i)`;
    polyCylinder -name ("agentBase_" + $i) -radius 0.2 -subdivisionsX 14 -height .01;// Make cylinder
    radial -position 0 0 0 -name ("agentRadial_" + $i) -magnitude 20 -attenuation 0.3 -maxDistance 4.0;
    parent ("agentRadial_" + $i) ("agentBase_" + $i);
    hide ("agentRadial_" + $i);
    rigidBody -name ("RBagent_" + $i) -active -mass 1 -bounciness 0
    -damping 10 -position 10 0 10 -impulse 0 0 0 -standInObject cube -solver crowdSimSolver ("agentBase_" + $i);
    connectAttr -f ("agentBase_" + $i  + ".translate")("PMAnode_" + $i + ".input3D[0]");
    connectAttr -f locator1.translate ("PMAnode_" + $i + ".input3D[1]");
string $exp = "float $cylPos" + $i + "[];\n";
    $exp += "$cylPos" + $i + " = getAttr PMAnode\_" + $i + ".input3D[0];\n";
    $exp += "float $locPos" + "[];\n";
    $exp += "$locPos" + " = getAttr PMAnode\_" + $i + ".input3D[1];\n";
    $exp += "setAttr ";
    $exp += "(RBagent_" + $i + ".impulse)";
    $exp += "($locPos[0] - $cylPos" + $i + "[0])";
    $exp += "($locPos[1] - $cylPos" + $i + "[1])";
    $exp += "($locPos[2] - $cylPos" + $i + "[2])";
    expression -s $exp -name ("walk_exp" + $i) -alwaysEvaluate true -unitConversion all;
cycleCheck -e off
I'm getting this error...
// Error: Attributes must be of float, integer, or boolean types: impulse //
But am unsure why/how it's erroring as it looks ok to me, anyhelp would be much appreciated.
Chris
try using 0.0 0.0 0.0 instead of 0 0 0 on a few occasions I think I have encountered commands that like to be reassured they are getting a float value.
