Studio Rendering Issue / Memory Swap Settings On Irix (2)
Hi Guys,
I need to re-render some Alias Studio models on an Octane System for a Client.
Unfortunately, the models are so large they cause the system to crash.
A friend more conversant with the UNIX/IRIX technologies told me I needed to add a line in the
/etc/fstab file to add additional swap and virtual swap memory at startup.
I would like to add 8gb swap and 8gb vswap to /dev/swap at startup.
Can anyone help with the correct configuration string?
Thanks,
flexo
here you go:
Add swap space: "/usr/sbin/mkfile 4g /dev/swap2; /sbin/swap -a /dev/swap2; nedit /etc/fstab" and add the line "/dev/swap2 swap swap pri=3 0 0" in your /etc/fstab.
Exports/mounts: "nedit /etc/exports"
http://www.gdargaud.net/Hack/UnixNotes.html
Thanks!! I'll give that a try
