i have a part of my character modeled with plygons, and is still in poly mode i am also trying to model another part through sub divs and then merge them… how do i do that?..is it possible for me to merge them?..if i model the second part in sub divs how do i go back to poly mode to join them ?..thanx
If you want the model to be “one” piece of geometry then you need to convert the subdiv section back to polygons and then combine them.
The conversion can be done using Modify->Convert->Subdiv To Polygon[]. Take a look at the help on the tool so that you get a handle on what the options do.
Good luck,
ww
thanx…
