hi there!
i'm modeling with subdivs and I want to see my polycage shaded!! not in wireframe.....I've looked everywhere but I can't find it!!!! where is it??? is it possible?? aaargh!!! ![]()
TinuZ
hi there!
TinuZ
I've never heard that there is a way to do that.
Why don't you use "smooth proxy" and when you're done with the base mesh you go in subdivition..
greetz
In the outliner, right click and choose 'show shapes', select the [modelname]HistPoly shape, and assign a shader. Just make sure you remove the shader assignment when you render, or delete the poly proxy entirely.
-matt
Naah just check primary visibility as vell as reflection refraction and shadow wisibility off and youll be fine.
TIP: you will gain a boost in viewports if you hide the subdivs from views becayuse they dont have to be updated. You can hide subdivs on aper view tbasis thisway it will still be wisible in reders as it should! (alternatively you can have one view with cage and one without!) Isolation is alos a good idea some times!
I knew it would be that simple!!! ![]()
thanx guys!!
