Subdivision manipulation: vertices and edges
I find that I am constantly switching between vertex and edges when I am trying to do detail work on a subdivision model. I like to select the vertex, and then switch to edges while I am moving the vertex so I can better see what my changes are doing. Is there a way to display both vertices and edges so I can stop switching? How I do it now is switch to vertex, select vertex or vertices, switching to edge (with vertices still selected) and moving the vertex while the edges are displayed, then switching back to vertex to pick another vertex or set of vertices, switching back to edge, etc, etc, etc. I feel like this gives me better control over the surface of the model, when I move a vertex without having the edges displayed, things look ugly real quick. Thanks…
select object click on select by component type (blue surface icon with red arow hovering over it in statusline the keboard shortcut is f8), then click on the vertex icon [clack square] and lines… they now are both visible.
Personaly i do this a bit differently i only modell with aproxy wich is flush history on regulary with mel. I let the proxy have a shading group so i se it shaded and hide the subdivs in that view. then i have a linked camera view next to this view that shows the smoothed version only. Thisway i se the true tropologty and the smoothed one clearly. Also now if i focus with space to just the proxy i get a significant boost becasue the smoothed surfeace isnt calculate3d at all.
Joojaa,
Thank you for your repeatedly helpful replies and suggestions. I have a follow up question. When I am selecting vertices, is there a way that I can draw a box to select vertices only on the surface that is facing me (and not get all the vertices on the back side of the model)? Maybe this has something to do with culling? I couldn
