Hi everyone,
I'm setting up a chartoon face for facial animation and was wondering which kind of geometry I would be better of using for my setup. Basically waht are the pros and cons.
I want to render my final work as subD geo. So I was wondering if it would be better setting my blendshapes up as subD's, or is it better if I setup with polys, and then have my base poly head act as a wrap deformer of my high-res subD render geo?
What are the pitfalls to either approach? I can see that when I playblast it will be faster as poly's, but I would like to use subD's for my final renders.
What approach are you guys using? Any tips would be great.
Thanks.
QUOTE(Sontaran @ 05/21/06, 02:49 AM) [snapback]237788[/snapback]
Why would you do that?
All you nee dis to gbind the subd and convert the poly to subd with history on its far moreliable thatway.
QUOTE(Joojaa @ 05/21/06, 12:51 AM) [snapback]237801[/snapback]
Hi Joojaa, thanks for your reply. I'm a bit confised by the workflow. Could you please clarify it. I'm a confused about how to convert the poly's to subd with history on. When converting my poly's to subD's should I set the "Subdivision Surface mode" to "proxy object" and keep it on always?
All of my geo is poly atm. I've got a base head and 20 blendshapes for it. I've been going back and forth between subD and poly while modeling the shapes.
Should I take all my blendshapes and the base and convert to subD, apply the blendshape defromer, bind the base subD head to my skeleton?
keep it at low levels as You can - do all character in polies, bind, blend them, rig them and then convert to polyProxy with history.. add subD shape to separate displayLayer and hide while working on animation/turn visible when rendering.
Hi drBlacksnake, thanks for making that dead simple to follow. Thats the way I'll go.
Joojaa has also elaborated on these points and has been explaining the issues around poly's and subD's, so I think I have a better workflow now.
Thanks again.
