Guys, help !
My maya project crash suddenly when I go to frame 1500 and the frames after ?!
this is the crashlog is someone can help me :
//=====================================================Maya Crash Report//=====================================================
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x517427F8Fault address: ED61A27A in C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll0001:000A927A Logical offset (see .map file for location)
Call stack:(0) section:offset Address Frame 0001:000A927A 0xED61A27A 0x01096620 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::computeLoopVector + 0x4A bytes Decl: protected: void TpolyGeom::computeLoopVector(unsigned int,class T3dFltVector & ptr64)(1) section:offset Address Frame 0001:00098280 0xED609280 0x01096660 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::completeColor + 0x17F0 bytes Decl: public: void TpolyGeom::completeColor(unsigned int)(2) section:offset Address Frame 0001:000150A4 0xF9E360A4 0x010966E0 Module: C:\Program Files\Autodesk\Maya2013\bin\tbb.dll (-exported-) Location: tbb::task_scheduler_init::initialize + 0x4DD4 bytes Decl: public: void tbb::task_scheduler_init::initialize(int)(3) section:offset Address Frame 0001:000142FE 0xF9E352FE 0x01096730 Module: C:\Program Files\Autodesk\Maya2013\bin\tbb.dll (-exported-) Location: tbb::task_scheduler_init::initialize + 0x402E bytes Decl: public: void tbb::task_scheduler_init::initialize(int)(4) section:offset Address Frame 0001:000A9547 0xED61A547 0x010968B0 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::computeFaceNormals_TBB + 0x187 bytes Decl: protected: void TpolyGeom::computeFaceNormals_TBB(void)(5) section:offset Address Frame 0001:000A911F 0xED61A11F 0x01096940 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::computeFaceNormals + 0x17F bytes Decl: protected: void TpolyGeom::computeFaceNormals(void)(6) section:offset Address Frame 0001:000A242D 0xED61342D 0x01096990 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::update + 0x17D bytes Decl: public: void TpolyGeom::update(unsigned int)(7) section:offset Address Frame 0001:000A5960 0xED616960 0x01096DB0 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::fastTriangulate_TBB + 0x100 bytes Decl: protected: bool TpolyGeom::fastTriangulate_TBB(void)(8) section:offset Address Frame 0001:000A3F1A 0xED614F1A 0x01097010 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::fastTriangulate + 0x100A bytes Decl: protected: bool TpolyGeom::fastTriangulate(void)(9) section:offset Address Frame 0001:000A2480 0xED613480 0x01097050 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::triangulate + 0x30 bytes Decl: public: void TpolyGeom::triangulate(bool)(10) section:offset Address Frame 0001:000A23BF 0xED6133BF 0x010970A0 Module: C:\Program Files\Autodesk\Maya2013\bin\PolyEngine.dll (-exported-) Location: TpolyGeom::update + 0x10F bytes Decl: public: void TpolyGeom::update(unsigned int)(11) section:offset Address Frame 0001:002E8CE2 0xEB509CE2 0x010971B0 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: TfileTranslator::write + 0x322 bytes Decl: public: int TfileTranslator::write(class TsceneFile & ptr64)(12) section:offset Address Frame 0001:002E6B92 0xEB507B92 0x010975C0 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: TglobalTranslator::writeFile + 0x3C2 bytes Decl: public: static bool TglobalTranslator::writeFile(class TsceneFile & ptr64)(13) section:offset Address Frame 0001:002E29F9 0xEB5039F9 0x01098980 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: Tscene::writeUIConfiguration + 0x1D9 bytes Decl: private: bool Tscene::writeUIConfiguration(void)(14) section:offset Address Frame 0001:002E311F 0xEB50411F 0x010989F0 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: Tscene::saveScene + 0x5F bytes Decl: public: bool Tscene::saveScene(bool)(15) section:offset Address Frame 0001:002E32EC 0xEB5042EC 0x01098A40 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: Tscene::doSave + 0x1C bytes Decl: public: virtual bool Tscene::doSave(bool)(16) section:offset Address Frame 0001:002B982A 0xEB4DA82A 0x01098BB0 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: TsceneOperator::saveScene + 0x39A bytes Decl: public: static bool TsceneOperator::saveScene(class Tstring & ptr64,class TsceneFile * ptr64,bool,bool)(17) section:offset Address Frame 0001:002B3749 0xEB4D4749 0x01098C20 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: TfileCmd::handleFileSaveFlag + 0x109 bytes Decl: private: bool TfileCmd::handleFileSaveFlag(class TargDatabase & ptr64,class TsceneFile * ptr64)(18) section:offset Address Frame 0001:002B79F7 0xEB4D89F7 0x01098C90 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: TfileCmd::handleFlags + 0x337 bytes Decl: protected: bool TfileCmd::handleFlags(class TargDatabase & ptr64,class TsceneFile * ptr64,class TnamespaceSwapper * ptr64,class TgraphDiff * ptr64)(19) section:offset Address Frame 0001:002B8E55 0xEB4D9E55 0x010990F0 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: TfileCmd::handleFlags + 0xE35 bytes Decl: protected: bool TfileCmd::handleFlags(class TargDatabase & ptr64,class Tstring const & ptr64)(20) section:offset Address Frame 0001:002B926B 0xEB4DA26B 0x01099260 Module: C:\Program Files\Autodesk\Maya2013\bin\Shared.dll (-exported-) Location: TfileCmd::doCommand + 0x39B bytes Decl: public: virtual bool TfileCmd::doCommand(class TargList & ptr64)(21) section:offset Address Frame 0001:000134E4 0xF1F344E4 0x01099340 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmetaCommand::newSyntax + 0x774 bytes Decl: private: virtual class Tsyntax * ptr64 TmetaCommand::newSyntax(void)(22) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x01099390 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(23) section:offset Address Frame 0001:000383D4 0xF1F593D4 0x010993E0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xC354 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(24) section:offset Address Frame 0001:00056560 0xF1F77560 0x01099410 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: SophiaExecutable::evaluate + 0x60 bytes Decl: public: union Value * ptr64 SophiaExecutable::evaluate(void * ptr64)(25) section:offset Address Frame 0001:0001A67C 0xF1F3B67C 0x01099450 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TcommandEngine::executeCommand + 0x4C bytes Decl: public: int TcommandEngine::executeCommand(class SophiaExecutable * ptr64,void * ptr64)(26) section:offset Address Frame 0001:00022481 0xEC8E3481 0x010994B0 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: TrepeatCommandManager::executeCommand + 0xE31 bytes Decl: public: bool TrepeatCommandManager::executeCommand(short,bool)(27) section:offset Address Frame 0001:000134E4 0xF1F344E4 0x01099590 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmetaCommand::newSyntax + 0x774 bytes Decl: private: virtual class Tsyntax * ptr64 TmetaCommand::newSyntax(void)(28) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x010995E0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(29) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x01099630 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(30) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x01099680 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(31) section:offset Address Frame 0001:000591CA 0xF1F7A1CA 0x0109A310 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: setMelGlobalStackLevelPtr + 0xFEA bytes Decl: setMelGlobalStackLevelPtr(32) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x0109A360 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(33) section:offset Address Frame 0001:000383D4 0xF1F593D4 0x0109A3B0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xC354 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(34) section:offset Address Frame 0001:00056560 0xF1F77560 0x0109A3E0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: SophiaExecutable::evaluate + 0x60 bytes Decl: public: union Value * ptr64 SophiaExecutable::evaluate(void * ptr64)(35) section:offset Address Frame 0001:0001A67C 0xF1F3B67C 0x0109A420 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TcommandEngine::executeCommand + 0x4C bytes Decl: public: int TcommandEngine::executeCommand(class SophiaExecutable * ptr64,void * ptr64)(36) section:offset Address Frame 0001:00022EC6 0xEC8E3EC6 0x0109A450 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: TrepeatCommandManager::executeCommand + 0x1876 bytes Decl: public: bool TrepeatCommandManager::executeCommand(short,bool)(37) section:offset Address Frame 0001:000134E4 0xF1F344E4 0x0109A530 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmetaCommand::newSyntax + 0x774 bytes Decl: private: virtual class Tsyntax * ptr64 TmetaCommand::newSyntax(void)(38) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x0109A580 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(39) section:offset Address Frame 0001:000582F3 0xF1F792F3 0x0109A5D0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: setMelGlobalStackLevelPtr + 0x113 bytes Decl: setMelGlobalStackLevelPtr(40) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x0109A620 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(41) section:offset Address Frame 0001:000591CA 0xF1F7A1CA 0x0109AB30 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: setMelGlobalStackLevelPtr + 0xFEA bytes Decl: setMelGlobalStackLevelPtr(42) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x0109AB80 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(43) section:offset Address Frame 0001:000383D4 0xF1F593D4 0x0109ABD0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xC354 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(44) section:offset Address Frame 0001:00056560 0xF1F77560 0x0109AC00 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: SophiaExecutable::evaluate + 0x60 bytes Decl: public: union Value * ptr64 SophiaExecutable::evaluate(void * ptr64)(45) section:offset Address Frame 0001:0001B857 0xF1F3C857 0x0109AD60 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TcommandEngine::executeCommand + 0x3B7 bytes Decl: public: int TcommandEngine::executeCommand(class Tstring const & ptr64,bool,bool,class TmelCmdResult * ptr64,unsigned int)(46) section:offset Address Frame 0001:000C2037 0xEC983037 0x0109ADF0 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: TscriptAction::execute + 0xA7 bytes Decl: private: bool TscriptAction::execute(class Tevent const & ptr64,class TinterpreterResult * ptr64 * ptr64)(47) section:offset Address Frame 0001:0001FF06 0xEC8E0F06 0x0109AF10 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: TrunTimeCommand::doCommand + 0x76 bytes Decl: public: virtual bool TrunTimeCommand::doCommand(class TargList & ptr64)(48) section:offset Address Frame 0001:000134E4 0xF1F344E4 0x0109AFF0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmetaCommand::newSyntax + 0x774 bytes Decl: private: virtual class Tsyntax * ptr64 TmetaCommand::newSyntax(void)(49) section:offset Address Frame 0001:00058D6B 0xF1F79D6B 0x0109B450 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: setMelGlobalStackLevelPtr + 0xB8B bytes Decl: setMelGlobalStackLevelPtr(50) section:offset Address Frame 0001:0002C130 0xF1F4D130 0x0109B4A0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xB0 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(51) section:offset Address Frame 0001:000383D4 0xF1F593D4 0x0109B4F0 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TmelVariableList::default constructor closure' + 0xC354 bytes Decl: public: void TmelVariableList::default constructor closure'(void)(52) section:offset Address Frame 0001:00056560 0xF1F77560 0x0109B520 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: SophiaExecutable::evaluate + 0x60 bytes Decl: public: union Value * ptr64 SophiaExecutable::evaluate(void * ptr64)(53) section:offset Address Frame 0001:0001B857 0xF1F3C857 0x0109B680 Module: C:\Program Files\Autodesk\Maya2013\bin\CommandEngine.dll (-exported-) Location: TcommandEngine::executeCommand + 0x3B7 bytes Decl: public: int TcommandEngine::executeCommand(class Tstring const & ptr64,bool,bool,class TmelCmdResult * ptr64,unsigned int)(54) section:offset Address Frame 0001:000C2037 0xEC983037 0x0109B710 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: TscriptAction::execute + 0xA7 bytes Decl: private: bool TscriptAction::execute(class Tevent const & ptr64,class TinterpreterResult * ptr64 * ptr64)(55) section:offset Address Frame 0001:00005527 0xEC8C6527 0x0109B760 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: Taction::performAction + 0xA7 bytes Decl: private: void Taction::performAction(class Tevent const & ptr64,char const * ptr64)(56) section:offset Address Frame 0001:000055B5 0xEC8C65B5 0x0109B7F0 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: Taction::doIt + 0x45 bytes Decl: public: void Taction::doIt(void)(57) section:offset Address Frame 0001:0011D44C 0xEC9DE44C 0x0109B820 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: Taction::qt_metacall + 0x4C bytes Decl: public: virtual int Taction::qt_metacall(enum QMetaObject::Call,int,void * ptr64 * ptr64)(58) section:offset Address Frame 0001:0013140F 0x6CFA240F 0x0109B8F0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtCore4.dll (-exported-) Location: QMetaObject::activate + 0x30F bytes Decl: public: static void QMetaObject::activate(class QObject * ptr64,struct QMetaObject const * ptr64,int,void * ptr64 * ptr64)(59) section:offset Address Frame 0001:0000EA10 0x6A7DFA10 0x0109B930 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QAction::activate + 0xE0 bytes Decl: public: void QAction::activate(enum QAction::ActionEvent)(60) section:offset Address Frame 0001:00423D9C 0x6ABF4D9C 0x0109B9C0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QMenu::separatorsCollapsible + 0x44C bytes Decl: public: bool QMenu::separatorsCollapsible(void)(61) section:offset Address Frame 0001:0042A152 0x6ABFB152 0x0109BA50 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QMenu::internalDelayedPopup + 0xA62 bytes Decl: private: void QMenu::internalDelayedPopup(void)(62) section:offset Address Frame 0001:0007B76C 0x6A84C76C 0x0109BBD0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QWidget::event + 0xCC bytes Decl: protected: virtual bool QWidget::event(class QEvent * ptr64)(63) section:offset Address Frame 0001:0042A4F3 0x6ABFB4F3 0x0109BC70 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QMenu::event + 0x2A3 bytes Decl: protected: virtual bool QMenu::event(class QEvent * ptr64)(64) section:offset Address Frame 0001:0002647D 0x6A7F747D 0x0109BCA0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QApplicationPrivate::notify_helper + 0x10D bytes Decl: public: bool QApplicationPrivate::notify_helper(class QObject * ptr64,class QEvent * ptr64)(65) section:offset Address Frame 0001:000283AE 0x6A7F93AE 0x0109BF30 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QApplication::notify + 0x62E bytes Decl: public: virtual bool QApplication::notify(class QObject * ptr64,class QEvent * ptr64)(66) section:offset Address Frame 0001:0000BE3C 0xEC8CCE3C 0x0109BF90 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: ThotkeyManager::saveOnQuit + 0x2FC bytes Decl: public: bool ThotkeyManager::saveOnQuit(void)(67) section:offset Address Frame 0001:0011A722 0x6CF8B722 0x0109BFF0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtCore4.dll (-exported-) Location: QCoreApplication::notifyInternal + 0x72 bytes Decl: private: bool QCoreApplication::notifyInternal(class QObject * ptr64,class QEvent * ptr64)(68) section:offset Address Frame 0001:000279FE 0x6A7F89FE 0x0109C060 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QApplicationPrivate::sendMouseEvent + 0x1DE bytes Decl: public: static bool QApplicationPrivate::sendMouseEvent(class QWidget * ptr64,class QMouseEvent * ptr64,class QWidget * ptr64,class QWidget * ptr64,class QWidget * ptr64 * ptr64,class QPointer & ptr64,bool)(69) section:offset Address Frame 0001:0009C78B 0x6A86D78B 0x0109C1B0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QApplication::winFocus + 0xA4B bytes Decl: public: void QApplication::winFocus(class QWidget * ptr64,bool)(70) section:offset Address Frame 0001:0009FCF6 0x6A870CF6 0x0109C540 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QApplication::restoreOverrideCursor + 0x9B6 bytes Decl: public: static void QApplication::restoreOverrideCursor(void)(71) section:offset Address Frame 0001:00018BD1 0x76A79BD1 0x0109C600 Module: C:\Windows\system32\USER32.dll (-exported-) Location: TranslateMessageEx + 0x2A1 bytes Decl: TranslateMessageEx(72) section:offset Address Frame 0001:000188DA 0x76A798DA 0x0109C680 Module: C:\Windows\system32\USER32.dll (-exported-) Location: TranslateMessage + 0x1EA bytes Decl: TranslateMessage(73) section:offset Address Frame 0001:0014923A 0x6CFBA23A 0x0109F9C0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtCore4.dll (-exported-) Location: QEventDispatcherWin32::processEvents + 0x3BA bytes Decl: public: virtual bool QEventDispatcherWin32::processEvents(class QFlags)(74) section:offset Address Frame 0001:0009F295 0x6A870295 0x0109F9F0 Module: C:\Program Files\Autodesk\Maya2013\bin\QtGui4.dll (-exported-) Location: QApplicationPrivate::translateTouchEvent + 0x8C5 bytes Decl: public: bool QApplicationPrivate::translateTouchEvent(struct tagMSG const & ptr64)(75) section:offset Address Frame 0001:0011904A 0x6CF8A04A 0x0109FA40 Module: C:\Program Files\Autodesk\Maya2013\bin\QtCore4.dll (-exported-) Location: QEventLoop::exec + 0x14A bytes Decl: public: int QEventLoop::exec(class QFlags)(76) section:offset Address Frame 0001:0011E2D0 0x6CF8F2D0 0x0109FA90 Module: C:\Program Files\Autodesk\Maya2013\bin\QtCore4.dll (-exported-) Location: QCoreApplication::exec + 0xE0 bytes Decl: public: static int QCoreApplication::exec(void)(77) section:offset Address Frame 0001:0000AC20 0xEC8CBC20 0x0109FB90 Module: C:\Program Files\Autodesk\Maya2013\bin\ExtensionLayer.dll (-exported-) Location: Tapplication::start + 0xC0 bytes Decl: public: void Tapplication::start(void)(78) section:offset Address Frame 0001:00003A4D 0x3FDE4A4D 0x0109FDE0 Module: C:\Program Files\Autodesk\Maya2013\bin\maya.exe (-nosymbols-)(79) section:offset Address Frame 0001:00015D23 0x3FDF6D23 0x0109FE60 Module: C:\Program Files\Autodesk\Maya2013\bin\maya.exe (-nosymbols-)(80) section:offset Address Frame 0001:00014FD7 0x3FDF5FD7 0x0109FF10 Module: C:\Program Files\Autodesk\Maya2013\bin\maya.exe (-nosymbols-)(81) section:offset Address Frame 0001:0001552D 0x76D8652D 0x0109FF40 Module: C:\Windows\system32\kernel32.dll (-exported-) Location: BaseThreadInitThunk + 0xD bytes Decl: BaseThreadInitThunk(82) section:offset Address Frame 0001:0002B521 0x7716C521 0x0109FF90 Module: C:\Windows\SYSTEM32\ntdll.dll (-exported-) Location: RtlUserThreadStart + 0x21 bytes Decl: RtlUserThreadStartEnd of stack
//crash log file name = C:\Users\student\AppData\Local\Temp\MayaCrashLog130205.1746.log//version = 2012.09.21.0357//cut = Fri 09/21/2012, 201209210357//current scene = C:/Users/student/AppData/Local/Temp/tempUIFilea04828//last tool: renderWindowSelectContextItem//====================================================//panel with focus: outlinerPanel1//visible panels:// modelPanel4 outlinerPanel1 //====================================================//Memory usage:// 2048.000 Mb Free Memory// 2048.000 Mb Free Swap// 963.957 Mb Current// 117.577 Mb Arrays// 17.658 Mb Pixel Map// 4.266 Mb Data Blocks// 59.297 Mb MEL// 0.137 Mb arguments// 0.865 Mb Transforms// 1.000 Mb NURBS AG// 3.500 Mb Render Cache// 0.125 Mb Keys//====================================================
