Hallo everybody,
i'd like to know if there is a possibility to place a Directional light (SUN) in the sun original right position inside a HDRI Pano 360°, concerning an Image Based Ligting eincironment (NOT a Physical Sun ans Sky).
I mean: when you use and HDRI to map a Skydome in the mentalrayiblshape, place a Directional light o renforce hdri illumination is hard, cause sometime sun is NOT visible in the HDRI or the sun is in a bad position, and could be very hard to place a Directional light to match the original HDRI sun direction.
I saw there is these great plugin: http://www.creativecrash.com/maya/script/geosun
With Geosun you can put the real sun position data inside the scene, but only in a physical Sun and Sky environment. What i need , in stead, is to place the sun with accurate data position in a IBL environment (mentalrayiblshape). THere is a way to use this plugin in this way? Or maybe have you others suggestion to dale this issue?
Many, may thanks for a reply!
