Surface tools in maya,how do i?
hi , what is the equivalent of surface tools in maya,I WANT TO DO PATCH MODELLING LIKE I DO IN 3DSMAX?FIRST WORKING WITH SPLINE AND MAKING PATCH OF 4 OR 3 EDGES AND AFTER APLYING SURFACE TOOLS IN MAX ,WICH TOOLS IN MAYA ALLOWED ME TO DO THIS SAME ACTION?
thanxs
you’ve got alot of patch creation tools
birail; square; loft.
Nothing quite like surface tools though.
Doing it this way may seem more time consuming; but you get cleaner surfaces; and you have a choice between bezier surfaces (what max uses with ST) NURBS surfaces (the aged old standard) Polygon surfaces; and subd surfaces (the newest fad for character modelling)
when all else fails; f1 to figure em out
cheers
Don’t forget your boundary surface tool in Maya..
thats a great tool overlooked.
A better solution would be to create out of different primitives and turn them live and create a patch network
I personally think this is faster, once mastered really is a very optimal way of modeling…
Yes, I also use this method for creating clean construction curves on a live poly scan or group of objects. You can then create your patches with boundary (my favourite way)
