QUOTE
Can somebody tell me how to switch between world space, local space and object space? In the manual I can only find the description of what it is but not on how to use it.
Well actually it is, they mention this in the general inner workings* , anyway double click on the move tool for tool options. Alternatively hold w down and lmb, or click the second most top left button above the channel box.
*They don't repeat stuff once they tell you something they assume you know it, the manual is meant to be read from beginning to the end.
QUOTE
Maya doesn't take the comma as a period. Can I switch these buttons somehow? Or assign a period to the comma on the numpad?
Yes define a new keyboard layout. Anyway my Maya accepts comma just fine.
QUOTE(bokaj @ 05/17/07, 12:16 PM) [snapback]266228[/snapback]
Also it seems to me that Maya (and other programms like Photoshop and Word) sometimes switches the "z" and "y" buttons in the middle of my work. So when I'm pressing Ctrl+Z it doesn't do anything. Is there a way to fix this?
Windows has this cool language switching feature, and by default its set to ctrl+shift or ctrl+alt varies a bit by country. Now the trick is to ask windows kindly to disable this feature. Go to control panel, select regional and language options -> languages -> details -> key settings -> change key sequence and unchek all. while your at it take the sticky keys switching off to wich is triggered by 2 quick shift taps.
QUOTE
edit: I have another problem sad.gif : I am trying to make a room. It is quite big and this happens when I scroll out:
select camera ,hit ctrl-a and edit the far clipping plane (its a good idea not to make the range between near and far too big so if you push tha far also push the near, however the range can easily be 100 times that but you can et artifacts)
or just type:
viewClipPlane -acp
