Is it possible to switch active camera in perspective window from MEL? I'm talking about: Panels->Perspective->SomeCam. I don't see anything going on in script editor when I do this and failed to find info about that in docs as well.
Basically I want to make some small compositing right in the preview window is there any better/suitable way?
You don't need to use "Shape" as part of the camera name.
CODE lookThroughModelPanel persp modelPanel2;
Coincidently, I was exploring camera manipulation earlier today - you might find this useful: Here is a script which will open a floating window with a camera viewport. The script uses a camera named audienceCam, but you could substitute the name of any camera in your scene.CODE { if ( window -exists Audience ){ if ( window -q -vis Audience ){ window -e -vis 0 Audience; } else { window -e -vis 1 Audience; } } else { // If the window doesn't exist, create it window -retain Audience; //-tlc is topLeftCorner, -wh is widthHeight paneLayout;// Attach Panel to window string $curModelPanel = modelPanel "audienceCam";// Note that if executed w/out variable assigment, the panel name is not created. lookThroughModelPanel AudienceCam audienceCam;// Look thru camName camPanelName modelEditor -e -da "smoothShaded" -displayTextures on -allObjects 0 -polymeshes 1 -nurbsCurves 1 -nurbsSurfaces 1 -gr off -sel off audienceCam;// da is -displayAppearance showWindow; } } If you execute the script mulitple times, it will toggle the visibility of the window. If you close the window, the script will reopen it and I think it will be saved with your scene.
Note that this script creates a window and a model panel, to remove them from your scene, you would use this code:CODE if(window -exists Audience ){deleteUI -window Audience;}; if(panel -exists audienceCam){deleteUI -pnl audienceCam;};
FYI: You can MMB-drag a cam from the outliner to the viewport to have the cam activated!
furthermore you can get the panel under the cursor with:
CODE getPanel -wf and you can switch the cam directly at a modelPanel: CODE modelPanel -e -cam persp modelPanel4; so you could do for instance:
CODE { string $thisPanel = getPanel -wf; if (getPanel -to $thisPanel == "modelPanel") { string $cams[] = listRelatives("-p", ls -cameras); string $activeCam = modelPanel -q -cam $thisPanel; int $switchToCam; for ($i = 0; $i < size($cams); $i++) { if ($activeCam == $cams[$i]) { $switchToCam = $i + 1; break; } } if ($switchToCam >= size($cams)) $switchToCam = 0;
modelPanel -e -cam $cams[$switchToCam] $thisPanel; } } browse the cams in the current panel. You could even exclude certain cams from the array before you loop it..
