Targa seq-movie file problem
Hi all
I am having a lot of trouble with importing a targa seq onto a plane.
I am using movie file node. I know to use frame extension and am doing so. I can get all the motion loaded when I use a quicktime but unless it is a maya rendered qt the alpha doesn't automatically input into the transperency.
When I use the targa seq I can't get the motion hapening at all and still no alpha into transprency node. I open the targas in Photoshop and it has an alpha. The quicktime renders I do out of After fx have alpha but do not plug into the transprency node. I'm OS X maya 5. It is truly frustrating. A good tutorial doing this exact thing would be great.
Any help?
thanks suzanne
i just tried the excate thing your speaking of and it didn't work for me either.
I dont know how to help you in that matter however, I do know a work around.
Just use a regular file node on the color switch, use the image sequence (check box) there with the tagra files you created. Your color and transparency node should connect automatically.
Do you have frame padding on those puppies too?
Hope this helps a little.
