Hi there,
I am trying to get a targa sequence with alpha channel to play as a file texture in maya. When I import a targa sequence as a movie it sticks on the first frame and the alpha channel doesn't work. Is this possible as I can only get an .avi to play at present? The alpha channel is essential for the project.
When I import it as a file texture instead of a movie texture the image appears but when I check the 'use image sequence' box the image goes blank and I get a black square when I do a test render.
I have come across some documentation that talks about adding file types to the 'getFileSequenceFormats.mel' file but I am not sure of the correct syntax to add targa files to this.
Can anyone help at all?
Thanks very much ineed!
