Test render of character
This is a character im working on useing Lightwave6.5. Its in concept model stage. let me know what you think.
thanks
BTW which cg characters would be more appealing to the average joe= real, medieval, or sci-fi (all highend)?
Looks Good…Stylized…I understand that the pic is still in the production stage but with the specular highlights the character looks like a plastic He-Man doll. Just an observation. Otherwise I like it.
The only critiques I have are:
The Sternocleidomastoid Muscle (in the Neck) (looked it up in an anatomy book so you could do the same and know which one I am talking about, in case you already do not)
This muscle seems to be different on either side. It may just be the way the light is hitting it but just in case take a look at it.
Also, the ear seems a little off on its design. The inner part is what concerns me. Again, without being there it is hard to point out but take a look in the mirror and take a look at the ear and you will see what I mean.
i like the eyes. Very Stylized.
I think maybe there is too much definition in the deltoids and the collar bone sticks out a little much.
Looks good though
Later
Thanks for the critique I’ll fix everything you just mentioned and more after I complete the entire body.
BTW what anatomy book are you using or recommend.
Everything looks good to me. I like this type of CG. The whole idea of photorealism is not very appeaaling to me (just use a camera), this reminds me of more of a 3D illustration. Good job. The only thing that bothers me is the colar bone. It is very off. Here it looks like a long tube. In reality it has alot more mass at the begining and end. The angle is also off. As for your other Q I think that sci fi tends to relate more to the medium but it is all a matter of what you have to bring to each different type. Go with what you want and it will work out best.
It looks good! Try to make the collar bones more S-shaped, like a composite bow of the eastern type, and maybe some more attention to the neck area…?
your useing Lightwave 6.5 for that right does that mean your useing sub ds
it looks cool as hell i like it
i tell you the more work i see being done with the sub ds the more i want to get into them just dont have the time right now
john I first start out building it polygon by polygon switching to subD adjusting the points. I use the extrude poly feature and use splines for guilds along with points from the splines converting them to polygons etc. You get the point, it’s just allot of different things you have to do and that
Sorry so late in the reply.
The Anatomy book is geared towards the artist
“An Atlas Of Anatomy for Artists by Fritz Schider”
There a few anatomy books out there that are good at focusing on the artist rather than the doctor.
The Hogarth series is really good.
Off the top of my head he is the only other author I can think of right now. Hope it helps.
I am with you on the Photorealism thing. ALL THE WAY!
matthewomen, thanks I’ll have to check those out.
I like photorealism only when it’s applied to the other two (med, sci) and has a really good story, thanks again for the info.
