Text info in viewports
I'm trying to print some info in the active view....
It seems that M3dView::drawText() doesn't do anything when called from within MPxCommand::doIt() or a MPxSelectionContext:o[Press,Drag,Release].
drawText() seems to only work from within draw methods.
So, how do I print text in the view as is done by the Heads Up Display->Poly Count or Heads Up Display->Frame Rate menu items. Also, how can I print text on the view from within an MPxSelectionContext::doDrag(). I know the mel command draggerContext can do this but I can't figure it out in the API.
Thanks in advance
-jd
