Texture-info and subdivs
I wonder: is there any way to keep the texture-coordinates made for a lo-poly object (in my case: some clothing) and/or transfer them when creating a subdivided version of it ??? Texture info gets a bit resized when doing it the geometry-approx-way, but is lost when doing “local subD-refinements” or creating “subdivision”-versions.
Unfortunately, for my clothing to work, I NEED a high-res version, with textures, without a proxy-cage, else that lopoly-cage would be used for simulation…
Hell-raiser@t-online.de
you’ll need XSI 2 (or somebody else with XSI 2)
Bonjour Hell-raiser,
Unfortunately, textures are NOT propagated on the subdivided model when you create a subdivision model. Textures are only propagated when you use Geometry Approximation.
This means that if you want to use a subdivision model, you’ll have to put textures on it, instead of the low-pol model :-/
Hope this helps
Salutations - Cheers
Bernard Lebel
Bernard - I assume that you also know that such a feature is indeed available in XSI 2, called Duplicate using geometry approximation
Well I don’t have XSI 2, so I didn’t know that. Thanks for the info, it sounds great!
But if Hell-raiser didn’t know that too, I assume this is because he does not have version 2 too. Given that, I’m not sure that knowing a version-2-only function will solve his 1.5 problem :wink:
Bernard
you might want to try using a camera projected texture…they seem to work well on our sub D models, with geom approx.
