The Difference Between Sub'ds and LowPolys is?
coming from 3dmax background
i have a diffcult , to find out about the difference
between Sub'ds modelling and LowPolygon modelling !!
in max , i was had a one method for modeling ( meshEdit ) plus MeshSmoth ..
so ..
any one of you guys , help me to have a knowledge about this ..
i am very good modeler , but not understand the differ !!
(sorry for bad language )
thanks
Bonjour st_petersburg,
I too come from a max background!
In fact there is no difference. MeshSmooth and Geo Approx do the same thing on polygons. They both subdivide the object, using the Catmull-Clark algorithm.
What is different is the tool itself. In max it's an operator (Modifier), and in XSI it's a property. Each software offer different options. In XSI you can have your subdivision level based on the distance from the camera.
One thing that I think is missing in XSI is the ability to set a different level of tesselation for rendering and in the viewports. This when the +/- keys are handy. Also, in XSI you can't freeze the Geo Approx, but you have an option to create a new object that will be subdivided (with Duplicate using Geo Approx).
So in the end, when you use MeshSmooth in 3ds max you are actually doing sub-d modeling. It's just labeled differently.
Hope this helps
Salutations - Cheers
Bernard Lebel
je vous remerci atyss !!
thanks for this ( FASTHELP !! ) Atyss
but you hadn't ansewr my main question :
IN GENERAL
What Is the Diffrence ( general diffrence at all ) between
Subd's And Lowpoly ..... ?
and forget what max and xsi is ....
( I belive It is The same process of work !! )
Where the diffrence lies ?
thanks in advance
wait ..
i may understand from your reply that the process is like this :
1- firstly , do lowpoly object
2- secondly , do subd's on it ..
so it is a levels of work processing
not a two diffrent methods , is that right ?
with not disturb you
you said
( subdivision based on the camer distane )
could you little explain , and what the advantage of this ?
thanks !!
In XSI you can have your subdivision level based on the distance from the camera. <<
??? How?
Markus
st_petersburg:
You are right. Basically sub-d is a concept that allows you to model in low resolution, then to smooth things up when its come to rendering. Well, in practice a low res model for broad cast can be up to 15 000 polygons (or even more), depending on the level of detail you want.
Markman:
Check this post, it explains it all:
http://www.highend3d.com/boards/showthread...&Main=85347
The only thing is that you'll have to scrub the timeline to see the subdivision changes when they occur.
Hope this helps
Beranrd Lebel
Ahh, okay, an expression.
I thought you meant a feature like viewdependant tesselation or so.
Thanks
Markus
Well it's not an implemented feature but does the same thing!
Bernard
