hi all,
is there an easy way to switch objects in maya? that is, i’ve done an animation with a shaded sphere jumping around and deforming etc. can i now switch it with a different object, like a face i modeled for instance (which happens to be very similar in shape and size), without redoing all the animation and deformers? i’m not sure if that’s a weird question or an obvious one…
Yes, you can do this by parenting the new object into the hierarchy of the ball you already animated (make the ball its parent, for example). Then, you can select your deformer and use the Edit Membership tool to add the new object into the deformation.
-JP
