I’ve heard with Maya (and Shake, for Apple) that you can literally one click rotoscope. I don’t know if this is true, but I plan on filming saber battles, and I want to be able to get a good visual effect quick. (Sorry if this has been posted before.) Is there a tutorial out there, or could anyone make one, for Maya that simply shows how this is done? The actors will be using either hollow transparent colored tubes or colored wooden dowels for the blade, whichever is better. Any help would be much appreciated. Thanks.
I know a little about Shake and do know that you can draw a roto-shape around the area that you want to take out. You just draw the rotoshape where you want it, then scrub through the timeline and move it again. If you have auto keyframing turned on you don’t have to set keys or you can set keys manually. You can move it to correct it. You would then take the rotoshape and map it into the alpha channel so that you can remove that part from the original.
As for Maya, if you’re animating something and rendering it out, if you have the alpha channel selected in the render globals, you will get an alpha channel that you can use to take out parts of the scene. In fact if you were to match the action in Maya, with Maya Live and the light sabers that you model and animate in Maya were in the right place, you wouldn’t have to draw a rotoshape in shake, because you could use the alpha channel generated by Maya instead.
For the blades, I would use either the green or blue color that they use for green/blue screening, so that you can take it out easily.
In the past i did lightsaber images of me with Photoshop.I made a lightsaber from a wooden stick and a metal pipe for the handle.
As about your request to do rotoscoping in a video ,must tell you that you shouldnt use Maya or other compositing software because the results aren’t so good as the method used in the official Star wars movies.This method includes Photoshop and Adobe premiere.I give you 2 links were you can read 2 tutorials for a home user. LINK1 LINK2
hmm… the person who rotoes a 2 minute lightsaberrcut with premiere and photoshop gets my thumbs up for lunacy.
Imean all comp apps can do this roto MUCH faster. Imean modern comp apps can even track the corners of the roto.
go to dvgarage they showhow to do this in ae.
The second link is good. Lots of Photoshop actions and processing.
However I have to say, that Joojaa is right. Stick some white tape at your sticks ends and use After Effects two corner tracking if you are experienced in the app. If you are inexperienced draw a mask adjust it to your movements key frames and let the computer do the interpolation for the inbetweening. (Saves lots of time and mental health…
Anyway, good luck and have fun!
Chris
