I have three machines in my house. two macs and a pc. All three have dual video outs. My only problem with this is that the pc has NT and i dont believe NT supports usb. Is swithing to windows 2000 worth the effort to usse the keyboard function. I prefer NT because of the low code overhead in the OS (im only using maya on it) and im really only concerned with the monitors, as i can always keep the keyboard to the side, but it would be nice to have ONE keyboard and mouse to control the whole shibang. Anyway, i guess my question is, is there really that much of a difference running maya under win2000 vs NT?
This may be a side issue to your concerns but I have a belkin omnipro and just wanted to point out some problems you may have.
The biggest problem was that I thought that I could get away with routing hi=rez video through this thing so I could control all my computers from one monitor but what I found is that even with high quality cables the switch adds ghosting and degrades the video signal significantly at resolutions over 600x800.
So what I ended up doing is putting the render node monitor off to the side and I have a direct video connection to my main system.
I looked at the description of the drbott switch and it doesn’t say much about supported resolutions except that it does dual vga.. I may be wrong but vga implies low resolution.. lower than svga which is probably what you need if you want to work at 1280x1024.
If anybody knows of a better switch than can handle HI-Rez.. let me know.
Actually, that’s the main issue. I currently just bought two lower end manual switch boxes for the monitors only (two individual ‘two in - one out’ ) And i get horrible ghosting. Ive never used switcher boxes before so i thought the cables were cheap (which they are:) Anyway, I guess this is a problem that plagues switcher boxes in general? I dunno. Im not sure what the best solution is here. Does anybody know of “High quality” signal switcher boxes for my setup (i dont even care about the keyboard setup)
Thanks again..
p.s. What exactly is it that limits the resolution with switcher boxes? Is it that the actual caliber of the cables cant handle the frequency?
Edited by squagmire on 06/12/01 06:31:32 PM.
Yeah I initially got one of those manual switches and it didn’t matter what kindof cable I used. Even with the belkin there is signal loss with high quality cables. I think the root of problem is cheap electronics inside the switch but you also need great cables.
I’m trying to rememeber who makes some of these products for longrun convertors but I know that the cost will be double or more.
Another route to consider is useing a software based remote control solution. This may not work for you though. I could probably get away with using something like timbuktu which uses software to bring th edesktop of the remote computer onto your local machine before you cannot do anything that incloves realtime feedback. But you could get away with managing rendering and the like.
During one project I was working at home and I could upload the scene to work and start renders there and the like from a 56k modem.
At where I work we use 100-150 of the suckers across 3 floors to remote display/audio/keyboard our octane workstations. They’re all running 1280x1024 and the majority run with flawless picture quality. Some do exhibit problems but its probably cable interference/older monitors but so far its the best performing ones that I’ve used.
CyBex longview is the model.. I’m not sure about price I think they are around 200$ or so per machine.
Now this is for a KVM extender.. the splitters should be cheaper.
