The X System, some questions!
Hey!!!
I really need some advice from an experienced users!
Im using Redhat 6.2 without the “X System” Comp.
I had some plans to start out with a “clean” Linux and
manually install XFree86 + Motif ( the main reason is
to learn more about the X system ).
I succefully installed XFree86 and it worked with some
special drivers for my OpenGL card. Then I downloaded
the rpm Motif package. I installed it with the rpm command.
Finally my questions:
  1. Where do I find the motif target dir??? Where is the
    files???
  2. How do I activate MWM in my XFree86 server, there is
    no wm as default when I start up the server ( just a clean
    screen with the Xterm) ??? Where is the config files???
/abel
To find the files installed when you install an rpm, use
rpm -q -l packagename
You can pipe it through ‘less’ to make it easier to read. So, if you installed, say, xdelta-1.1.1-3.i386.rpm, you’d execute
rpm -q -l xdelta | less
As for starting up MWM - I believe that if you put that command into ~/.xinitrc (you might have to create this file) it will start up MWM when X starts. (This might not work if you’re using a session manager like xdm or gdm.) Create a .xinitrc file that looks something like this:
xterm &
/path/to/mwm
Andrew Klaassen
Alternatively, if you lust want to test out Motif (or any window manager) from your bare X session, type “mwm” in your xterm window. The window manager frames and widgets should pop up. When you exit the window manager, it should drop you back into the bare xterm. Type “exit” in the xterm window, and the entire XWindow system shuts down.
