This is driving me mental
I have an emitted starfield particles ..... which i have instanced nice glowing blinns to them..... looks sorta like stars....... and then i render the in MAYA, just one frame..... they look wild, fantastic..... supberb....
i batch render them and all the stars dissappear........
Is this because they are classified as hardware ????
in the hardware buffer it only shows the actual particles (not the instanced stars) so i cant just render the stars in hardware and then composite them over the software........
Why is the batch render looking different than a normal render in maya? they use the same render globals dont they?
arrrgghhh....
im losing sleep and sanity over this... (my girlfriend isnt to happy either )
humm you have used the particle instancer? In that case it should work as long as you make a disc cache out of your particle anim!
But you cant use batch render for hw particles you must use the hw renderer for that (ot is after all screen capture), use hw buffer -> render-> render sequence if you need hw particles. Altough to be honest it sounds like youve instanced the thing!
ok, ill try caching it.....
I understand that the particles are hardware and wont render in s/w, but what about the intanced objects??? they show up in a normal s/w render..... just not when i batch render.....
Is it possible for things to show up in a single frame render? render->render in new window.... and then not show up in a batch render? render->save batch render.....
Isnt this sort of the same thing, except one is a single frame and the other is a time period.....
No no it sould work as long as the particles are present in that frame!
