QUOTE(silk @ 12/29/07, 07:24 AM) [snapback]278883[/snapback]
i'm not near a machine with afx but there might be an animation preset you can apply to your text layer.
if not a simple expression along the lines of position.X = frame() or something to that effect.
can't script without a manual in hand sigh
anyway, once you've typed your text in, set the font etc the script will take care of the rest.
This would still require using a conventional layer for the text, and if you need continuous scrolling text for long periods of time mean working with an unmanageably wide layer, or having to mess about animating and synchronizing many narrower ones...
I was really hoping to find that there is a plugin that is specifically set up to create this type of effect easily....
