I'm getting a very poppy emission, for a few reasons. I have a big container, long in one direction, my voxel size is like 20, 60, 20... I've tried doubling that and it helps a little. My scale is the same as above. I also need to emit pretty fast so I get poppy shapes when they first come onto the scene. I have e volume emitter and it slides acress the container. As it does so the fluids pops on. Any tips on making a smoother emittion? Anything you've found, or does anyone else have this problem? Thanks!
hi,
to make a smoother emission:
create a fluid cache with higher over sampling rate:
fluid effects->create cache [] (select the box)
and then set
sampling OVER
Rate 2 (or whatever).
this will sample the fluid emission 2 x for each frame (so on the frame and on the 1/2 frame).
the higher you set it, the more samples. unfortunately, i don't know if you can set it for only a few frames. so it will over sample the entire animation... let me know if you figure out a way of limiting the oversampling. you could try caching just the portion of the shot during emission and then resetting the oversample rate and appending to the cache, but i think this may give you a jump/pop in the fluid.
-czc
Hey, thanks for replying! I haven't messed with over sampling much, I'll try it, and let you know how it turns out. Thanks again.
-Dave
