How to make instance duplication of shadingNode ?
If anyone know method to solve this problem - please help !
I'm not sure, maybe SWITCH utils ( Single, Dobule, Tripple ) will help me, but i'm not sure !
Thx, Regards !
Thx, Regards !
you dont, but thats no matter a unlimitted number of different shaders can use the output of one node! thet means a texture can be shared by many shaders theres no limit to this. Also a swich node can be used to feed the same node different data depending on the need.
But thares not much benefit from this other than having only one place to change things from wich can be accomplished in many ways! But switches can be usefull!
