i have a group of objects that i would like to transform along a diagonal, meaning along a line that is not parallel to any of the xyz axis. at the moment i cant really do it, i have to go x and then correct the y value so the new position is on line with the old position.
sure that is exactly what i am doing now. but i dont want to do that anymore, it takes too much time and involves a calculation every time, its not very handy. can i change the orientation of the pivot so it can easily be transformed along axis not parallel to world xyz ?
I want to move an group of objects. without rotation i can easily move that group along the xyz axis. now, when i rotate that group, its local xyz axis has been changed, but i can still only move it along the world xyz, unless i do a movement into the y and x diretion to get to the point in space i want to reach . basically all i want to know is if there is a way to get the transformation/move tool to adjust to the local rotation axis of an object or if it always will orient itself along the world xyz
