I need to capture velocity of an object to get secendory animation. The way I'm doing it right now is- getting current and previous frames translations calculate velocity and then rotate joints accordingly
may its not required at all. is there a innate function in maya which can
get velocity
translate velocity in rotation, say x translation gets converted into -ve z rotation.
wouldn't any secondary motion depend on the acceleration vector, not velocity? either way I can't help you out though. lightwave gives you a graph of velocity...
if U rememenber coorectly the cacheNode should get you about were you want for doing secondary motion, but not by converting translation acceleration to rotation..take a look you'll never know..
There were a post on that few month ago, maybe try to do a search
