I get some weired results when I calculate data based on the bounding box from trimmed surfaces, basically the bbox is calculated from the "untrimmed" version of the nurbssurface.
Is there any tool or script or similar in Maya which makes it possible to "convert" a surface and get a correct representation of "timmed" surface, I simply want a correct bounding box and not something based on a old trimmed version.
Trims dont affect the geometry at all they make the polys just dessaper in a sense (even dynamics will react to the whole object). So you would need to set this manualy and indeed calculate yourself. This is not a very easyoperation so is thare are a few of theese ovbjects then i suggest you do it manualy.
I would stringly recomend that you use rebuild with trimconvert option if possible (unlimitted only). Using trims in general is a very bad idea (ina maya and most visualisation progs, caes are a different story but they automaticaly trim out everything outside the trim anyway) indeed, unless its the only way to do it offcourse.
also whats the point of making huge surfaces and then trime only a small part of them?!?
