I'm trying to render two spheres with a shader I got from "Essential Renderman Fast" by Ian Stephenson. Unfortunately, I keep getting errors:
chriss@mazindol:...testing/in/chris_renderman/essential_renderman/chap24>render test_spheres.rib
P01001 {ERROR} Unregistered request: "fov" (at line 8 in test_spheres.rib)
P79014 {ERROR} RIB syntax error (at line 8 in test_spheres.rib, last token 'fov').
T02001 {ERROR} Can't open texture "envmap.jpg" [ Object: Shader: reflective]
The error seems to originate from rib at the MakeCubeFaceEnvironment command. Here is the text of my rib file:
Display "test_spheres.tiff" "file" "rgb"
Format 640 480 1
Projection "perspective" "fov" [100]
LightSource "ambientlight" 1 "intensity" [0.2]
LightSource "spotlight" 2 "from" [-1 1 0] "to" [0 0 3] "intensity" [3]
MakeCubeFaceEnvironment "posx.jpg" "negx.jpg" "ceiling.jpg" "floor.jpg" "posz.jpg"
"negz.jpg" "envmap.jpg" fov "gaussian" 2 2
WorldBegin
Translate 0 0 2
Surface "reflective"
#Left Sphere
TransformBegin
Translate -1 0 0
Rotate 90 1 0 0
Sphere 1 -1 1 360
TransformEnd
#Right Sphere
TransformBegin
Translate 1 0 0
Sphere 1 -1 1 360
TransformEnd
WorldEnd
I noticed that no environment map is being generated. Does anyone know what I am doing wrong? I'm rendering with Pixar Renderman. Thanks.
