Troubles mirroring a group!
In a SW Walker tutorial, im making the legs of the model with poligons and revolved nurbs. I create an empty group and move there the group with the leg, BUT when i mirror it, it just mirror one Poligon of the leg instead of the whole group. What should i do? PD. I'm using Maya 3.5 in a Mac OsX
well you should make sure you have the group selected before you start mirrotring... Clicking on a objct select that object you se no matter how it groupped unless you are in leaf mode. So select the object and hit the arrow key down to select the parent!
Thanks for answering, but the trouble remains... I just make the whole leg, with poligons and revolved nurbs, them i make a group with the whole leg, them i create a empty group and move there group of the leg. Them in the Hypergraph i select the group and clik on Polygons>Mirror Geometry and it just make the Mirror Geometry in one Poligon of the group.
Well, if you have any idea please drop me a line. Thanks!
Cesar
oops sorry arrow down but it still seems to me thet you are mirrorin only that one object instead of the group..
so open the otliner check that the objects are in the group select the group and only the goup then try duplicating it and scale by -1 on the mirror axis and then reverse the normals!
Instead of polygon mirror!
Ok, perfect! it worked just when i put the value -1 at Scale in x, at the Edit>Duplicate options menu, instead of the Polygons>Mirror geometry that only mirror one piece instead of the whole group.
Thanks a lot!
Remember that this flipped the normals so you need to un flip them!
