TrueGlass Shader Help
Hello,
I am just getting started in working with Mental Ray/shading as well as some of Maya's more advanced tools. I'm currently creating a scene that requires a window and downloaded the TrueGlass Shader.
After applying the shader to the panes of glass, I am now confused. What is the purpose of the 3D texture (which appeared when I applied the material) surrounding my mesh, and why does the glass only seem to reflect nonexistant "squares?" To make matters worse, because this will be a night scene, these "squares" appear as gaps in my glass.
Any help for this noob would be greatly appreciated.
Thanks,
Strider212
because thats what the shader does the rerflection map is there to accomodate for some environmental effects. Glass fdoent looklike glass without reflections. But thing is you should replace this reflection map with something appropriate.
Just because something has a snazzy name doent mean its mant for your actual purposes. The etrm glass actually cover s a whole lot f different kinds of materials even in real world, not just hundreds of differently behaving materials but tens of thousands.
