Modeling potential…?
www.mattmuyres.com
You have some pretty strong pieces in there, nice texture work too, along with the modeling.
The first thing that I think would help out is to use a higher-res quicktime file, or give an option for one. With such low resolution and all of the compression, it was hard to see the detail. Despite bandwidth limitations or whatever it may be, it’s well worth it to properly present the work you’ve done.
Also, if it hadn’t been for the title of your post, I wouldn’t know from watching the reel that you’re shooting for hard-surface modeling. I would suggest at least throwing some text up next to your reel so people know what to pay attention to. But overall, great job on the reel.
The reel is bad for many reasons.
A) its too long
its not focused
C) it contains a mix of medicore and good works, medicore out
D) too compressed and small
Animations were nice, a bit unlively tough but pretty ok some good some bad. Modells werent realy great most of the time, but tahts okay if yur going for animator, but not if modelling.
Nothing spectacular.
If i was you id concentrate on animation.
I’m sorry to say that your reel is pretty woefull for so many reasons. Its way too long. I nearly switched off during the seemingly endless grey page of your name and details…this should be at the end. However, not many people will ever get to the end of your reel because the work is not inspiring or even the slightest bit interesting. Your animation skills need a hell of a lot of work. There is no personality whatsoever in any of your ‘characters’. Your modelling is fairly mediocre…but salvageable if you pay more attention to your use of texture and colour. Your colour pallettes are almost primary, and very garish. Your attention to lighting setup is none existent.
A showreel should not last longer than a minute.
Sorry, to sound so negative…but I assume you were seeking honest and objective opinion?
