When I use the mental ray render diagnostics it tells me:
Filter type of file node “file1” (Quadratic) is not supported.
But when I change the filter type, it clearly has an effect on the texture during rendering.
Suddenly a wall model that has a bump map to it will not render this particular map. The shader is still connected to the surface and it is displayed correctly in the viewport. Is that a common bug or what else could be the problem?
I am using:
mental ray for Maya 7.0
mental ray: version 3.4.5.2
QUOTE(montecore @ 07/31/06, 07:57 PM) [snapback]243891[/snapback]
2)
Maya and mentalray support different sets of texture formats! use different format. (maya does not SHARe the memory with mentalray its just converst its description to mr so because maya does not store files it passes tham as reference and mr may decide it deos not know the format, same appears in reverse mr acceps many ofrmats maya does not know).
QUOTE
1)
Bu its still micght eb a different filter than you think
QUOTE(Joojaa @ 07/31/06, 08:16 PM) [snapback]243899[/snapback]
But it did work. Why would mental ray “decide” in one instance to display the bump map, and in another that it doesn’t konw the format.
My bump map is maya-iff and as I said: It worked and then after adding to the scene it ceased to work. The changes that I made had nothing to do with that wall or the wall shader so I figure there is no connection. The only think I did, I imported a shader from a diffent scene. But I checked, there are no naming problems (as far as I can tell) and as I said the bump is displayed in the viewport when I preview the textures …
QUOTE(montecore @ 08/01/06, 01:30 AM) [snapback]243918[/snapback]
It still proves niothing if maya sees something does in no way mean or imply mr should. They are not the same program even tough the other is built a s a library into the others executables. They are 2 separate programs, period. Even tough theres been great deal of hididng the fact from you.
Post a ma file (and whan i say ma i mean ma not MB) zipped up with problematic texture offcourse.
QUOTE(Joojaa @ 08/01/06, 10:35 AM) [snapback]243957[/snapback]
Thanks, I solved the problem. I just reprojected the texture and it worked. Don’t ask me why … Somehow the UV-Map was “out of order”.
