two sides
how i can texture both sides of polygon?
one texture on side one, and other texture on side two.
/vic/
you could use a planar texture projection on the polygon.
Then in Render Tree you can use the 2-sided node -forgive me I can't remember where that is - to texture either side of the polygon.
-Vijay
In the Rendre Tree, just use the switch 'front-back' (nodes -> switch -> front-back). Then plug the two textures you want in that switch.
flord.
yes, it's cool node!
I can use different material, textures, etc on each side.
/vic/
