UI problem
Hi all,
I pressed a wrong MEL button.. and...
the top right of my interface.. >X< minimize/maximize, restore
buttons on the main menu... they're all gone. Is there a script to bring them back? I can't seem to find a display option through the interface.
Thnx in advance
I think all you will need to do is restart Maya. If this still does not bring back all of the items missing, try deleting the file in your user preferences directory called "userPrefs.mel". Then restart Maya and all should be back.
Hope this helps,
Morris Olmsted
3D Designer @ Idol Minds LLC
molmsted@idolminds.com
Yo...
Restarting was the very first thing I did when it happened.
So I knew that wouldn't work. I tried to delete the userPrefs.mel... no luck there either. Thanx for the suggestions though.
Any other takers?
try this:
window -e -tb 1 -mnb 1 -mxb 1 MayaWindow;
