Unable to install softimage licensing
hi everyone,
when i run the softimage licensing, everything goes fine at first. after the progress bar of coping files finished, the dialog shows the following msg:
Severe
Cannot start Flexlm service.
then the setup close immediately
what’s wrong with it?
anybody can help me?
thanks!!!
Did you update your license for XSI? You can get one directly from web site if you have support contract.
If you changed your license file, did you remember to start and stop the license server again (or reboot)?
Do you have different versions of your license file in the same directory (ie: flexlmlicenses). On occassion the flexlm server uses the wrong license file even though only one is called softimage.lic. Put your backups etc. in a subdirectory called backups.
Do you have dongle connected after other dongle or device, like a scanner. Try connecting Soft dongle first.
I would recommend calling support, they handle these kinds of problems all the time.
Urp
