Underground base... [For the Spider|BOT]
This is still a work in progress… I’ve got lots more texture work to do… Things may even end up a bit cleaner… There there will definately be some animation on the screen and the lights on the pillars will be blinking red… And stuff :slight_smile:
As always comments are appreciated.
Regards,
PM
It seems you also bevel your geometry, so it catches highlights, which is good, but a few crits about this pic:
  • Stay away from precedural shading as it comes, it sucks. You’ll get interesting results with them if you use them for a particular look or effect you’re going for.. otherwise stay away from them, go trecking around with a digital camera and get some textures on a cloudly day.
-Everything is too eucledian, and boring.. the tubes at the top with smaller tubes coiling around them however flow much nicer already. The eye likes stuff which repeats, and the ratio of this repetition is important. Try to get a few more things flowing.. depends what style you’re going for I guess.
Try to be more specific regarding what aspects of your pic you want crit for.
Pretty good.
I like everything above the platform, but below could use some more detail. Just add a bunch of machinery (junk) and cables etc. Make it look like you wouldn’t want to fall down there…else, why build a platform at all.
I agree about the procedural textures. They aren’t a too bad from this perspective, but when you get closer for the actual production, I think the textures are going to take away from the image. I’d simply use traditional 2 textures. This will let you put seams and other details too.
Look forward to seeing the project progress.
Urp
Thanks to both for the comments… I do definitely plan to work on the textures more… I do need to be more specific… The only things here that I’ve spent more then an hour on are the lighting and modeling. Though I’m trying to a toned down look, and would rather just have some vague shapes/shadows below the platform then real detail… I don’t want to detract too much from the character when it makes its appearance.
Will-do on the textures, as I mentioned below, they are just testers… I’m at a bit of a loss as to how to apply some of your other information though. I had planned on going back and messing some stuff up a bit more. Twisting the catwalk plates a bit and such…What I
