Underminding the manual
heyall,
try as i might, i can't past an image onto a grid in XSI 2.0. i've done exactly what the manual said to do, but it just doesn't work. can any of you tell me a way that will? also, i need to paste a video onto a grid. i know it's a similar technique, but i need specifics. so if you all don't mind, please help.
thanx,
uncletoon
Can you describe how you applied the texture? That would help track down the problem.
For videos, it is exactly the same. The only difference is that when you are prompted to pick a file, you can pick a sequence or a video file. Sequences are recognizable because you have the name of the files, followed by parenthesis. Pick that.
Hope this helps
Salutations - Cheers
Bernard Lebel
