Unreal Tournament Actor
Hi, I’m developing an actor for U.T., this is my first try and lots of problems come out at every step; at this link you can see a printscreen of the model (legs skin not finished yet):
http://www.geocities.com/audellah_14/index.htmhttp://www.geocities.com/audellah\_14/index.htm
The main problem is that the web is full of tutorials for 3ds max, but there’s nothing for Maya; AM I THE ONLY PERSON IN THE WORLD USING THE ACTORX PLUGIN FOR MAYA (downloadable from this site)?
In the mesh/refpose export to .psk file I get the X_ModelInfo.log file looking like this:
Unreal skeletal exporter - Model information for [Orkz.psk]
Skin faces: 0
Skin vertices: 0
Skin wedges (vertices with unique U,V): 0
Total bone-to-vertex linkups: 0
Reference bones: 30
Unique materials: 0
= materials =
This is quite wrong, if there is someone that can help me…
Thanks
Aude
Ah, good 'ol actor-x and Maya We were using the Unreal 2 engine for awhile at my last job, so things might differ a bit from UT. Nice model and textures btw.
Well from the look of the .psk it looks like he’s not bound to a skeleton yet. No bone-to-vertex linkups. So I would guess you don’t have a .psa (animation file) yet. Have you generated the script for him yet (axOption), .ux I think. It’s been awhile since I’ve done this, but if he isn’t bound to a skeleton the .psx is worthless. Just try bringing him in as a static brush if you want to see him in the editor.
On the material end you have to name each shader a certain way for it to export correctly. The naming convention is skin00 for the first and skin01, ect for the each new shader. Plus there are flags for each as well. If you need the shader double sided with an alpha channel you need to have your shader named like this: skin00_2sided_mask (order doesn’t matter). Then open up the .ux file in notepad and check to make sure that your shaders are all named correctly and manually enter in the texture names, if you have to.
Open up the .ini (can’t remember which one) file in the system directory and scroll down until you see the line for EditPackages. Add the name of your .u file here.
After all that make sure you have the directory for him setup right. Should look something like this for a directory structure:
(this is in the root of the unreal directory) model_name>(then 3 folders inside that dir) classes (holds the .ux), models (holds the .psx and .psa), textures (all your textures).
Then just open up a dos prompt and go to your UT directory and type ucc make. It might throw out some warnings but just check you system folder in UT and see if there is a .u file in there with your model name.
It seems like a lot of stuff to do, but you get pretty fast with after you do it a few times. Best of luck!
lata
Thanks for your reply, a bit late however, I managed to solve the problem some days ago. Here are two shots of finished skins:
http://www.geocities.com/audellah_14/skarz.jpghttp://www.geocities.com/audellah\_14/skarz.jpg
This is my very first character setup, and for the binding of the mesh to the skeleton I used strange mel scripts found in the Maya help; in Maya that worked well, but for ActorX not very well, so I learned a little about smooth skin and painting weight maps, then worked well.
Oh, I also tried to compile it this evening but looks a total mess in unreal editor, when the actor will be ready I’ll let you know…
Mmmmm…sorry, I wrote wrong links, oh I hate to write wrong links…
http://www.geocities.com/audellah_14/skarz.htmhttp://www.geocities.com/audellah\_14/skarz.htm
http://www.geocities.com/audellah_14/red.htmhttp://www.geocities.com/audellah\_14/red.htm
The only thing I would say is that it doesn’t really convey the dark gothic nature of Warhammer 40,000. He is a big bright and needs to be a little bit more Orky…
WAAAAAAAAAAAGGHHH!!
or something :0)
Peter
I’m not diggin the green. the colors are WAY too saturated. This looks more like a character from Everquest than Unreal. (not that there is anything wrong with Everquest, it’s a great game if you are a shut in and don’t need to keep a job or a relationship)
