Does anybody know if there is a way to unwrap a nurb surface into a flat sheet? I have used other modeling packages that had this ability (PDGS, Pro-E). Example: If I were modeling a car seat and wanted to unwrap some of the panels so that I could plot it. This way making a pyshical part from my model would be possible. HELP PLEASE!
umm unwrapped nurbs surfaces are perfect squares!
I think your trying to do this for multiple reasons ie. manufacturing etc. A lot of CAD programs allow users to unwrap objects so that they can measure and use for general analysis.
However, there is a third party MAXscript I used constantly at my previous job for unwrapping Polygons named 'Chilli Skinner'. Basically it would first explode the polygon into seperate polysurfaces and based on user defined selections of verts would then re-weld those backup. When done correctly you could then morph the object flat for use in seamless low poly texture mapping. Although the company I worked for created Design Visualization I used this tool constantly for objects etc.
With a physically unwrapped object there isn't a better template for mapping period. Unfortunately the more complicated the surface the less it paid off - too impossible.
check out www.scriptspot.com and do a search for chilli skinner
Wind-
If you are trying to unwrap a surface for mapping reasons and not for manufacturing you can basically do this same thing in Maya or MAX by using the UV mapping utilities. It will automatically unwrap surfaces into smaller parts based on the angle change between multiple surfaces. Then stitch those seams together and you will have hopefully not always a seamless UV map paramater for which to texture. You can also get a psuedo accurate representation of your surface unwrapped by looking at the UV finished map.
Hope that helps,
Jason Brummett
Ahh are your surfaces trimmed?! theres a way to look how the curves are laid on the surface in maya in 2d.
I had to go and look what pro e does to get the picture. Not exactly the same but very close. Since maya doesnet make compound shells. offcourse the easiest is to export iges and then unwrap in pro-e
